Group: DynoMotion Message: 14182 From: Moray Cuthill Date: 12/1/2016
Subject: KMotion feature request
Is there any chance the C Program screen could have the ability that each tab/thread/page/whatever you want to call them, remembers where they were scrolled to?
I've just started to work on the required programs for my mill, and have just been reminded about the fact the editor resets to the top of the file each time you select a different thread. It get's a bit annoying when I'm switching between files/threads to check/edit things, and I have to keep scrolling back down to the bit I need.
Oh, and is there any way you could add a line number box somewhere?
If an error in an included file gets flagged up, I either need to manually count the lines in the problem file, or load it into notepad++ to locate the problem line.
Moray
Group: DynoMotion Message: 14183 From: Dan W Date: 12/1/2016
Subject: Re: KMotion feature request
I second that request. I have to bounce back and forth between the built in editor and Notepad++.
Then again if I had the time to figure out how to make a custom plugin/template for Notepad ++ I would just use that.
-Dan
Sent via the Samsung Galaxy S®6 active, an AT&T 4G LTE smartphone
Group: DynoMotion Message: 14184 From: kn6za Date: 12/1/2016
+1 on that!
Andrew
Group: DynoMotion Message: 14185 From: Tom Kerekes Date: 12/1/2016
Hi Moray,
We'll look into keeping track of the Line Numbers your at.
Did you know you can right-click on the screen and select Show Line Numbers?
Moray
Group: DynoMotion Message: 14190 From: Tom Kerekes Date: 12/1/2016
Hi Moray,
It seems to be working and should be in the next Release.
On 12/1/2016 5:17 PM, Tom Kerekes tk@... [DynoMotion] wrote:
Hi Moray,
Moray
Group: DynoMotion Message: 14193 From: Moray Cuthill Date: 12/2/2016
Thanks Tom.
And no, I never realised you could turn on line numbers by right clicking.
Would it be worth having them turned on as the default option?
Moray
On Fri, Dec 2, 2016 at 2:21 AM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi Moray,
Hi Moray,
Moray
Group: DynoMotion Message: 14196 From: Tom Kerekes Date: 12/2/2016
Hi Moray,
Once Show Line Numbers is selected it should persist forever.
On 12/2/2016 2:08 AM, Moray Cuthill moray.cuthill@... [DynoMotion] wrote:
Thanks Tom.
Moray
Hi Moray,
Hi Moray,
Moray
Group: DynoMotion Message: 14233 From: Moray Cuthill Date: 12/6/2016
thanks for adding the editor view memorization.
Regarding the line numbers, I was meaning to have them displayed by default when KMotion is installed.
Another thing I thought about earlier, was would it be possible to add the ability to add a user action to the Single Step button?
On my lathe, I rely on a C program assigned to the user action for the cycle start button, which prevents code from running if certain conditions have not been met (machine homed, and tool changer initialised).
As I discovered when originally setting the lathe up a couple years ago, the Single Step button bypasses those checks, which thankfully only caused me some head scratching at the time, but could of potentially caused some damage. It would be good to be able to apply checks when using the Single Step button.
Moray
On Fri, Dec 2, 2016 at 7:09 PM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi Moray,
Thanks Tom.
Moray
Hi Moray,
Hi Moray,
Moray
Group: DynoMotion Message: 14235 From: Tom Kerekes Date: 12/6/2016
Hi Moray,
How about having the same Action performed on Single Step as with Cycle Start?  Can you think of any reason someone would want them to be different?
Moray
Hi Moray,
Thanks Tom.
Moray
Hi Moray,
Hi Moray,
Moray
Group: DynoMotion Message: 14239 From: Moray Cuthill Date: 12/7/2016
I did think about that option, and it would work fine for me.
I have been thinking there may be some situation where somebody may want to do something a bit different between Cycle Start and Single Step, but I'm struggling to think of anything.
Moray
On Wed, Dec 7, 2016 at 12:41 AM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi Moray,
Moray
Hi Moray,
Thanks Tom.
Moray
Hi Moray,
Hi Moray,
Moray
